- Jan 10, 2001
I have a 32 inch Magnavox LCD. It started turning itself off after a short time and also turns itself on if it is left off. I have found a lot of folks with the same problem. I stumbled on a post that stated that they used inferior caps on the power supply and that replacing the bad caps would fix the issue. The poster found this by visually inspecting the caps and said that they were bulging. Mine are not bulging that I can tell but do seem kind of loose inside the cap itself, if moved it does not feel solid like the wires going into the caps might have a bad connection. The caps in question are CapXom 1000uf35v. Anyone have any knowledge of this brand? Would I get the same rating for replacement caps or should they be better higher rated?
Been a long time since I fooled with stuff like this, high school was a really long time ago and I remember almost nothing about this stuff anymore. TIA
