Some people try to drive square pegs in round holes everyday.
Ya just need a bigger hammer to get it to go.
Let me try this again. Which specific CPU (955/965/1055/1090T)? Different CPU's have different IMC and this can be an issue when using multiple sticks of RAM.
I still believe you would be better off using matching sticks of RAM especially since you will be having so much open at once. I use Adobe CS and do photo editing on an i7 920 with 6 gig and have found it to be plenty. This is one of the few cases where the intel seems to win over the AMD.
Do you have a big hammer? If not just use any RAM certified Phenom II compatible. It's easy.
http://www.corsair.com/products/phenomii/default.aspx
You're good to go with the Vengeance! CgS says you need a "Big Hammer" to make RAM work these days... so I was just asking.
Ken that looks good, what motherboard are you looking at using? The 1090T has a good IMC and I am looking at going with that myself later on once AMD comes out with the new design, I am hoping that will drop the price of the 1090T. I don't do fireworks or anything like that myself but I do use CS a lot where I shot LF and MF stills, mostly B&W.
Ken, are you just out to make a dedicated rig for editing or are you trying to build something for faster editing with adobe?
http://www.tomshardware.com/reviews/xeon-x5680-5600-series-westmere-ep,2692-7.html here is an article about CS5 talking about multi core, HT and video card testing to give you an idea about CS5, I use an older version that is 32 bit so I don't fall into the same category as you do.
