- Nov 18, 2010
Wow, snowbrdd, this is quite the undertaking!
1. Google Sketchup. Check it out. It has literally hundreds of easy-peasy tutorials to follow online, and just after a few of the basic ones, you'll be able to crank out 3-D prototypes pretty quickly, with everything to scale.
2. Paper Mache, Toothpicks, Cardboard, and Copper Wire. This project has some fairly complex shapes and curves - might I suggest making some small models? Make a 1/4 size cutout of hard-drives, optical drives, and motherboards and make a basic frame out of copper wire, see how all the components will fit, and how all the weight will be supported. You can even make a little model person and chair to make sure everything will be the right height.
3. SATA Cables, if I'm not mistaken, are limited to 3 feet. Keep that in mind. Optical drives have a bit more leeway, in the sense that you can use USB instead of SATA, and then your length limit goes to 10 feet.
