Here's what I propose... Yes it's me again!
Try to scrounge together enough to buy an AM3 cpu... A 555BE is only $90 and that's only $20 more than your current budget.
Once you know you can afford that cpu shoot me a PM and I will send you the following, yours to keep at no charge, but you have to make the little effort and get the AM3 cpu on your own.
I know there are cheaper AM3 chips, but to be honest anything less than a 555BE would just be a major case of suck; and with any luck you'll get a 555BE that unlocks to a quad-core and then you'll really be set for a good while.
GIGABYTE GA-880GM-UD2H AM3 AMD 880G ---> It's not the best overclocker by any means, but it has happily brought my 555BE to 3977MHz with the extra two cores unlocked and been able to run benchmarks there. I also added a bunch of
these and
these to the MOSFETs so they'll be a bit cooler than on the stock board.
CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) --> Not the best/fastest memory out there, but on that board and with my 555BE they will do 1720MHz without a problem.
The items above have been in daily use for the past three or four months and are in perfect working condition. I was going to retire them now that I got better components coming in, but they'd be better off being enjoyed by someone else than sitting in my closet collecting dust.
Does that sound like a good deal?
Let me know
Sebastian
