Do you mean run it off a virtual machine and not virtual drive? Virtual drive is like a fake CD/DVD/HDD.. so if it can run as a live image that'd be fine, but virtual machine would let you install/load up another OS while inside xp
Hi
Your dealing with a newbie as far as this project is concerned. The faststone ran into a conflict with my trucrypt software I think...during attempted installation the faststone loading was unable to complete.
To clarify I want to run my programe off of a virtual drive which Im supposed to create using my existing hard drive...now is this possible and what software can I use to setup the virtual drive. Again its not a virtual machine issue its a virtual drive I need to install without the use of CD or DVD.
Ill take a look at 120 and daemon option, but Im still thinking that a confilct may occur here to as my HD is trucrypted...? Any thoughts on that?
