http://www.businesswire.com/news/ho...es-Chipset-Design-Error-Implementing-Solution
Damn I just bought a complete new system to replace my ancient Opty 165.
I wonder if I should RMA this ASUS P8 P67 pro or hold off till it and if it goes tits up.
great my mobo is due to be in tomorrow meh i only run 2 hard drives, if the ports start to fail il just get a pci controller unless they are gonna send the replacement board first lol i sold my 1156 board to get this one!
If you only have 2 drives you don't even have to worry about it. It only affects the 3Gbps Intel ports. On my board for example I've got 6 other ports I can use before needing the Intel 3Gbps ports (2 intel 6Gbps, 2 marvel 6Gbps, and 2 jmicron 3Gbps)
This is most certainly uncool. I just installed on sata 3 ports. Joyous. Another reinstall.
I notice that NewEgg de-activated the Asus and Gigabyte SB boards.
Shouldn't have to. It's native support. As long as you switch to the intel-controlled 6G/s ports it should be as simple as swapping the cable (and maybe boot order if you have multiple drives installed).
Asus P8-P67 pro:
SATA 3Gb/s 4 ports
SATA 6Gb/s 3ports
2 xSATA 6.0 Gb/s ports (gray) by P67
1 xSATA 6.0 Gb/s ports (navy blue) by Marvell PCIe SATA 6Gb/s controller
SATA RAID
Intel Rapid Storage Technology Support RAID 0,1,5,10
Ok the 3gb/s ports are affected. I will use my new SSD drive on the Marvell port, put the 1tb hd and dvd burner on the Intel 6gb/s ports.
Move the other drives to my backup machine since they are backup files anyway and keep the 1tb external drive as my secondary backup.
I suspect in a month or so I can RMA and get a revision 2 board. May everyone else find a happy solution till this mess can be fixed.
He probably won't experience this error, but I still feel like an *** for suggesting this "awesome" new platform.
I talked to NewEgg they said ASROCK boards are not affected?
How can this be its the same chipset?
