- Aug 5, 2002
PSU... how many cards you planning on putting in that system? Man after figuring out my wattage via kilowatt meter.... even my system is using 1/3 the power my PSU puts out.
For PSU are you sure its squeeling? I swear my PSU was doing it at first when I originally got it since it was new. Though it ended up being my GPU's doing it. 8800GT, 285GTX had a very nice squeel to it. This one has a slight one, not nearly as bad as the others but it is there. Pretty hard not to notice it when its sitting less than 2 feet from you and you have 240x120mm hole with 2 fans right at the GPU level in the side of the case.
Well I think I know why I was unstable. Everytime it reached 82c-83c it would just freeze. I guess when I was in game I can't monitor temps but it would reach that temp. I don't think my fans were aggressive enough so I tweaked it in Afterburner. Now again I'm at 940/1450mhz, upped the fan to 50% just for stability testing and passed 3 loops of vantage, and more than 30 minutes of Kombustor. What is a safe temp for this card? I've seen people saying they were using it passed 90c. Again I came from having a card never going above 60c so it topping at 80c isn't really joyful for me. Problem is the fans are loud as hell. I have a HAF X with at least 8 fans and I'm using a 120mm fan GPU attachment that put a 120mm fan right in front of the fan for my 6970 and that isn't seeming to help that much even though the fan does 70cfm. Was I crashing because of temps or it wasn't stable? I believe temps because I've done extensive stability testing with high fan speeds but in games, where I used a lighter fan profile it has frozen. Any thoughts?
Edit- Finally found a true Crysis stable clock at 1.2v at 925/1450. Not the best and would have hoped for better but I'll take it.
Technically speaking you can probably take the card up to 100C. I've heard stories of tech support saying thats ok. Personally I wouldnt take it past 85C. Also realize that your temps while running kombustor/furmark are probably gonna be substantially higher than in a game.
And the temps are making you unstable
This isn't the one I was talking about. On TechPowerUp, you upgrade to the 6970 BIOS which isn't what I want. I want to unlock the shaders. Might sound confusing but many people were killing their memory because they aren't the same. I suggest you use the unlock shader BIOS instead of the 6970 BIOS. Anyone else can you help?
Apparently people have measured the memory voltage and it doesn't actually change (can't find where I saw this ). Though the timings might change and it could potentially cause damage. Regardless, you lose nothing by using a modded 6950 bios.It ups the memory voltage which is why it's causing damage to many cards. Play it safe and just unlock the shaders.
If you follow the modded 6950 bios tutorial linked here, you can then unlock the OCing with MSI Afterburner. Details are near the bottom of this thread:Ok, so just shaders then oc from there? I'll try that.
Actually you'd be shocked. Right now I'm running 6970 speeds at 1.1v which is the stock voltage for a 6950. I could probably squeeze 900 without a voltage increase. I also replaced the Thermal Grease and got a good 4c at least with it.
I used Noctua TIM that came with my D-14. To flash get GPU-Z and save your BIOS with it. Get the 6950 unlock tools that was linked earlier and run that program with your original BIOS and it will give you an unlocked BIOS for you to use. Download the TechPowerUp 6950 to 6970 package. Now replace the 6970 BIOS with your 6950 unlocked shader BIOS. Rename it the same. Now run the batch file or ATI WinFlash, whatever that starts the flashing to begin. Make sure your BIOS switch is on the 1 position or it won't work at all. That's how I did it so hopefully it'll work for you. http://www.techpowerup.com/wizzard/Mod_BIOS_HD_6950.zip Here is where you download the tools to unlock your 6950 BIOS.
If you get an error like ID mismatch or Could not erase ROM, then you'll have to do some extra work in a Windows command prompt (or DOS): Run atiwinflash -unlockrom 0 followed by atiwinflash -f -p 0 bios.bin where bios.bin is the path and filename of the HD 6970 BIOS you downloaded.
kayson, That's where I'm getting the error message, in the command prompt.
BT, I did all those things except getting the flashing to begin. Winflash said "could not erase ROM", and the cmd prompt gave me the error message "'atiwinflash' is not recognized as an internal or external command...."
