- Jul 27, 2010
- Maryland
Hey, I'm having problems getting my card to flash and it's probably because I have no idea what I'm doing. I know theres that Tech Power Up way of doing it with a 6970 BIOS but I DO NOT want the 6970 BIOS, but the 6950 Unlock shaders BIOS. Meaning it only changes the shaders, not the voltage and clock speeds. I've downloaded the shader unlock package that others have referenced but I'm not sure how to use it. It says put your original BIOS and then run it. It then gives you a modded BIOS so I tried ti use ATI WinFlash and flash to the Modded BIOS but it said that my card couldn't erase the ROM. I know there is something I'm not doing right and would really appreciate help from the people who have done it. Thank You
