- Jun 24, 2002
- California, US
So I'm planning on building an automatic fan controller that will either be controlled by speedfan or the temps from a k-type thermocouple plugged into my res. Possibly learning how to program a basic PIC microcontroller that would change fan speed based on delta of ambient to cpu block outlet. What would you guys go with?
The Speedfan version would be the easiest as I'd just use a emitter-follower circuit. My issue is if my asus would output a linear voltage if plugged into a 3 pin instead of 4 pin since it's supposed to be PWM. Don't want to deal with a PWM circuit as I want it to be quiet and I'm running all Gentle Typhoons so the amount of heat dissipated by the op-amp would be minimal. I'm just afraid of startup current for the motherboard header which is the reason I don't just plug all the fans directly into the fan header.
Based on just water temps I have the issue with ambient changing (summer vs winter) which will cause the fans to run faster during idle.
Wish I knew how to integrate a circuit with windows program that could control the fan speeds based on ambient temps, water temps, cpu temps, and cpu load. Then I'd do some fancy fan controls that would ramp up and down at slow speeds to maintain a good temp.
