- Mar 10, 2011
yea just a stock cooler
You need something better before overclock that CPU, with the stock cooler the temps that you will get are not good for the lifespan of it.
The stock cooler isn't the best to use but, since you've got an X2 instead of something bigger, you should have some room to overclock - even with the stock cooler.I just have no idea what to do to over clock the ram video card and cpu
I'm sorry but two of these are too small for me to read the numbers and one is a broken link of some kind. Trents has the right idea.
Looks like you've got one of those boards that scrambles the CPU information. (ASUS is notorious for that.) I could be wrong but I don't believe the TJMax (Tctl in AMD terms) is 99° for that CPU, and that throws all the other information in doubt. For unknown reasons some boards just don't mesh well with CoreTemp or HWMonitor, which will also have problems. The only option I know of is to use the CPU socket temp as read by PC Probe II. If you can grab that program from the ASUS website and try again it would help a lot. I think you'll see much lower temps with PC Probe II.here they are
Did you try using PC Probe II to see if it's CPU socket temps were the same as HWMonitor?Actually may sell this box i have someone that wants it for 500...
