advanR said:Currently typing on my new 1.1a PC.
I did what i said before but i used better wire to make the two connections. Ill post my overclocking experience later. hoping to make it to 145fsb.
the guy dancing at the left is me. hahaha
btw my pc booted with 1.45v
thank you all for your help.
advanR said:I can only load windows at 120fsb. At 124 or anything more the system freezes when the bootloader starts. Thats even up to 1.7v. I can boot at all the way up to 142fsb w/ 1.7v but cant do anything above 120 stable.
Is it possible my problems are motherboard related? Could it be better to connect different pins? Or is this weak voltage regulator thing likely. At 1.7v asus utility shows 1.7v precisely.
thanks
advanR said:holy crap that worked. but I still cant load windows. before it froze during the bootloader. now i get to the windows loading screen and it freezes.
I remember that you have the same motherboard as me. Did you encounter any of these problems? Are there any other BIOS settings i need to change?
Spajky2 said:It should be enough just clearing cmos...but it looks like you are the OC-guy .. .. it would be better to get a lower frequency Tualatin (change order!) & running it only @ default Vcore not OC-ed too much!; this mobo looks like is not supporting Tuallies very good /weak voltage regulators!/ & also Abit does not recommend using CPUs more than 1G & Tuallies just drain so much current! They were some dead BH6 already with passed time IIRC; the last I know is from a guy to whom I sold the modded Slotket 2 weeks ago /he was running T1,2@1,488 but only for a few days, than the mobo blown up! So take care! & hope you have at least 250W quality PSU & mount also some small heatsinks on voltage regulators behind Slot!
Spajky2 said:Yes someone did (repair) IIRC but few months later blown the MoBo anyway; so I recommend using 1G /the lowest/ or 1,1G Tuallie & OC it (IMHO your v.1.1 mobo has 1/4 fsb/pci divider) a bit on default Vcore if not having problems with AGP card; Always play safe & do not be mad about MHz race! to long live the setup happyly! I am running on my the same generation MoBo /MS6163pro/ Tuallie @ default Vcore 1.0A@1,35G /the CPU alone can go w1,8Vcore till 1,6G stable on fiends mobo!!! /OEM Philippines march 2k2 lapped/ but because my Mobo has some issues with current supplying, i keep it this way; nice superstable, cold, silent & fast setup with W98SElite!
