- May 8, 2011
- Michigan
I have a Diamond Radeon HD6970 card, non-reference, so I have two fans. It seems to be working perfectly whether stock or in overdrive. But, I have been getting a fan noise lately that I can't explain.
It is a quiet pulsing about 2-3 cycles per second. I can only hear it when all my case fans are at low rpm. I think most people wouldn't even hear it over my other fans, but I do. It is noticeable at GPU fan speeds of 20-30%, but I don't detect it over that speed -- don't know if that is due to fan speed changing or the fans are louder at higher rpms and I just can't hear it anymore. I don't recall hearing the sound when the card was new (about 45 days ago).
The sound is similar to what one hears in a bedroom ceiling fan that isn't perfectly balanced -- whoosh, whoosh, whoosh. Since the sound doesn't relate directly to the 1000+ rpm of the fans, could it be some aerodynamic harmonics that are set up between the two fans? I can tell, however, the sound comes from just one fan. If I place my finger lightly on the center of the fan while it is spinning, the sound stops.
Second question, I have never disassembled a GPU card before. Any challenges with popping a fan out and replacing it if I can get an RMA fan from Diamond rather than having to replace the whole card? I am thinking I would rather have them send me a fan rather than lose my card for a week or two or more before getting a card replaced.
