- May 20, 2011
Hi all,
since few days (since I changed my i7 2600 with an i72600k, the pc has the following problem:
every time I try to turn it on it goes on for a couple of seconds, before automatically turning off and back on again after another couple of seconds. Every time this happens, my keyboard is not recognized anymore (but this is another sotory ).
What do you think it might be the problem?
Thanks a lot
Solution: I just disassembled everything, put back the CPU only, cleared the cmos, put back everything except 3/4 of the RAM (just put 2 out of 8Gb). Switched on and it worked. Turned off again, put back the RAM left, on again and magically it all works...even the keyboard issue is fixed now. Before disassembling I also updated the BIOS to the last version...
Thanks a lot
