just move the sound card to a different slot.
there is nothing REAL that you can do beyond that.
the explaination is rather long. and my info Old, and i will screw it up
1) --A---B----C-----D----
2) --B- -D----A-----C-----
3) --A---B----C-----D------ Plus all the extra new lanes and things witn PCIE
4) --C---A----D-----B-----
5) --A---C----D-----B----
this is (sort of) your pci slots
say you have sound card in
it is ^ connected to the hardware using C, which is assigned to IRQ 13 ?? i donno
You can reasign C to IRQ 14 and everything ELSE that is still on C will also be reasigned
so the conflict you will observe will go from 13 to 14 , and it wont make a lick of differecne
because it is using the same recognition point in the HARDWARE
but put the card over here
and ^ it might pick up on B instead, and whatever was on C will no longer conflict.
again how the SOFTware assigns the numbers is not the problem, it is back some in hardware.
Of course this is just a juggling act, The hardware has usually been designed so there is rare Large conflict. There are also the onboard items, which any your not using should be turned off in the bios.
Generally these things that end up on the same hardware connection share just fine. Multiple things can easily be on the same point untill you get some thing that sets latency wrong, or is not following the rules properly.
Also IF there are any PCI latency items in the bios, setting them HIGHER will allow an item to finish and reduce problems, but nowdays the hardware itself likes to change the latency , which can effect that whole channel.
Some hardware uses more than One of these connections for its board recognition .
weird isnt it, after thousands of pages of web stuff, i found out that i was thinking it all backwards, and it drove me crasy till i saw INTELs explaination.
again IRQ conflics dont exist in todays software (in thier dreams) they never existed at all, it was all hardware,
Plus it could be something else that is having problems altogether.
other things you can check for on your video card: run CPUz go to mainboard tab, and check your links ammount, should be 16 or at least 8.
none of the words used in this post are proper technical terms, and PCI lanes and all have changed a lot, the more they change the more they stay the same.
