- Jul 27, 2010
- Maryland
Hello everyone, I would like to know your thoughts on this subject as I know a little but would appreciate more clarity on this subject.
I just ordered 8gb of this RAM http://www.newegg.com/Product/Product.aspx?Item=N82E16820231416. It's CAS 9 at 1.5v.
I previously replaced this http://www.newegg.com/Product/Product.aspx?Item=N82E16820231193 with my current Mushkin Ridgeback's because they had a weird Motherboard issue where you had to save and exit the BIOS for them to work (don't ask why) so I gave them to my parents, but their board was MSI and they are having that same issue, don't really know if they are screwed up or if they just don't like MSI boards. My current RAM works flawlessly but my Parents are pissed at the RAM so I'm buying this 8gb kit so they can receive my Ridgebacks. Sorry for the story
Long story short, I'm getting a new 8gb RAM kit and will definitely use it in my system, duh. But the question is, should I install the 4gb kit so I can have 12gb? I can run the RAM at the exact speeds and timings, I'm just concerned whether mixing 2gb and 4gb RAM modules is a good idea. I'm fine with 8gb, but I don't want to waste the $100 I originally spent on that 4gb kit. 8gb is enough but 12gb would be icing on the cake. Don't worry about the compatibility issue I had with that kit before, it worked just on annoying circumstances, and if I do get that issue, then I will take them out for good. Just want some opinions on what I should do with the extra RAM.
