- May 23, 2002
I'm trying to figure out the best way to do something...I've checked with other people in my unit and no one has a solution.
I'm trying to:
create a roster of people...i.e. (in a "master" tab) name in A column, rank in B...etc with some detailed information
Then in a second tab, label it personal info (I'll have 5 or more separate tabs with basic name./rank then specific information), I want to copy the info from column A and B from the master tab (which is easy) , but then when I sort from master tab, it sorts the info in the personal tab, and all the tabs.....
The problem I'm running into....if I'm on the "personal info" tab, and I add information in say cell C5...then go back to the master tab and sort by rank instead of name, the information in "personal info" C5 stays in the same spot(even though the actual person changed, the row information stayed in the same spot)....so even though the names/ranks in the A/B column changed since they referenced the master tab, the cells beyond that stay the same....so nothing matches up.
This is kind of confusing....but if you're an excel guru I'll be glad to work with you!
I've also thought about having one massive master tab then just hiding the columns that aren't used/needed in the specific tab...i.e the master tab would have personal info as well as physical fitness...but if I clicked on the physical fitness tab, I wouldn't see the personal info (because I'd just hide it)....the problem is if I add a column/row I'd have to redo every sheet (if I just referred back to master from everything)
Obviously aggressive management of the data could keep this in check but the goal is lock many of these tabs and allow easy manipulation of data which will propagate throughout the sheet.
I'm trying to:
