just wondering if 80 plus gold vs silver vs bronze has a big effect on overclocking? does gold provide better OC'in numbers or stability? or is there any difference at all?
Essentially, gold/silver/bronze is a rating of the conversion efficiency of the unit. Units with higher efficiency will pull less power from the wall at a given load and in turn produce less heat. While a higher rating often says something about the overall quality of the PSU, it's essentially an efficiency badge and nothing else.
Zero effect on overclocking DIRECTLY. Its just efficiency like Johan said above. One can make an argument that a more efficient PSU has less ripple/noise etc, but those two certainly dont go hand in hand.
