You need the active display port.
Your sig says you have a pair of HD4850's. Are you planning to upgrade, as those won't support eyefinity.
I just got a single HD6950 (visiontek) with plans to go eyefinity.
I updated my sig, so you know what I'm going to run.
You need a 5xxx series + for Eyefinity sorry. But when you do get a 5xxx series + card you ou can get a Powered Display Port to DVI, and then run 2x monitors off the DVI already on the card.
Okay thanks a lot guys
