- Dec 30, 2009
- Las Vegas, Nevada
I have a bunch of 120 mm PWM LED fans. Each fan has 4 LED's which are not switched. They go on when the fans are powered. The fans are powered by either motherboard headers or through a fan controller.
I would like to install a device to manage fan illumination. Ideally, I'd like to reduce the illumination or actually turn the LED's off while not disturbing the rotation of the fan blades.
Inspecting the fans, each of the two leads from the LED's go to a circular PCB around the hub of the fan.
I have two ideas:
1. I can cut one of the two leads from each of the LED's and bundle all these ends to one side of a rheostat. Take the other ends of the cut leads, bundle them and place them on the other side of the rheostat. This is very messy and admittedly not very elegant.
2. The other idea was to possibly isolate the power from the PCB that powers the LED's and place them in a rheostat controlled circuit. However, I don't know if I can isolate the power going to the LED's without also interrupting the power going to the motor windings.
The approaches I've mentioned are hack quality and I'm looking for a better solution. I welcome a better plan.......please!
I have two ideas:
