- Jul 27, 2010
- Maryland
Hi, My problem is that my 875K's turbo boost multiplier config doesn't seem to work. With the K processor you can choose the multiplier for how high the cores can go depending on how many are being used.
For example if all core are used you can set it to run at 4ghz. If 2 cores are active you specify it to run at 4.2ghz and if you have 1 core you can make that run at whatever you want.
The problem is that all 4 cores are at 4ghz and they never change. I run Prime 95 and I go to task manager so it will only use 2 cores or 1 and I take a look at the Turbo boost monitor or CPUZ and it stays at 4ghz, never once goes up.
Anyone know how to fix this issue?
