- Jun 25, 2008
Wow. So DELL sticks it to me again. I had the same problem about a year ago and now I am hoping there is a cheaper solution.
The problem stems from the FACT that DELL supplies their laptop battery with an EEPROM which counts the number of chargers you apply to it. The thing that is silly is that if you unplug your laptop to move it (even if its turned off), the EEPROM counts this unplug/replug as another charge. So when the counter expires, it shuts down the charging ability of the battery regardless of the condition of the cells. STUPID. It should be criminal.
Anyway, I have been doing some searching and only found one application (so far) which gives user access to the EEPROM. The program is called Battery EEPROM Works but it requires an external I2C adapter (whatever that is).
Is there any software which can be installed on the associated laptop which would give the same reset ability ???? Is there anything else I can try ?
I have tried running the battery dead but no good, the EEPROM still keeps its memory.
PLEASE help me.
PS... Stop buying DELL !
PLEASE help me.
