I have a HTPC which had a 5450 and win732 and was trying to get an old game to work without lag. I tried overclocking it with Catalyst's software but the screen freaked out and the computer would restart and load desktop but if I had to do anything that took any graphical power at all (including opening catalyst) it would freak out. I tried uninstalling the software/driver and a reinstall multiple times with no luck. I didn't think the card was bricked or anything, but used this as an excuse to upgrade to an HIS 6570.
Now, here's where the real problem is. I installed the latest 11.7 catalyst amd said was for my new card (which was the same version I downloaded when trying to get the 5450 to work it seems) and everything went fine except the performance was still where I put it when overclocking the 5450. In other words, the maximum memory clock speed it will go to is 1000 when this card should go be set at 1800 by default. I've tried reinstalling while windows update is off, telling it to delete all software and drivers when uninstalling, and deleting the ati folder that was left in the programs folder after an uninstall with reboots between uninstall and installs and the problem still exists. I assume there is some hidden file on my drive that catalyst uses to load the performance settings that's not getting deleted. Where could I find this file or what else could I try aside from reinstalling windows to fix this? Thanks
