- Jul 12, 2011
- MN, USA
Hi. I usually use my computer 3-4 hours a day since I built it almost 2 years ago. The PSU i've been using is the cheap one that came with my case. It says '500 watts max'.
I used it last night for a few hours, and turned it off.
When I pressed the button power button this morning, the case lights and power LED pop on for half a second and then go off. If I try pressing the power button again, nothing happens.
If I switch the power button on the PSU off and back on, it will do the same thing.
I can smell a little bit of that electrical burn smell if I smell near the vent on the PSU.
So, do you think my power supply would just stop like that?
I'm hoping it's just the PSU, as I don't want to build a new computer till Bulldozer comes out.
Is there a good 650 watt modular supply somebody can recommend that is under $90?
Thanks!
Thanks!
