- Feb 23, 2011
- Toronto, Canada
Converting a two slot card into one slot.
I need a way to convert a 2 slot card into a one slot card. A waterblock will be used to slim up the main bulk of the card but the double slot connectors also need to go.
The top portion needs to be removed. I'm hoping someone with electrical knowledge of DVI connectors and chime in on whether or not severing the physical connection between the card and pcb will electrically be the same as having the connector in place but unplugged.
