Results 1 to 5 of 5
  1. #1
    Join Date
    Oct 2011
    evga gtx 460 fan shroud removal HELP!!
    Ok I cant seem to figure out why my fan shroud will not come off and i cant find anything thing on this vast world wide web..... getting very annoyed cause this shouldnt be so hard please someone help I need to put my vga water blocks on these things .
  2. #2
    Senior Member
    OnDborder's Avatar
    10 Year Badge
    Join Date
    May 2001
    HOT 'n Arizona
    Welcome to the Forum! http://www.ocforums.com/showthread.php?t=491697
    I'm assuming you took out the screws on the backside..
    It looks like there might be around 11?
    Sometimes you need to wiggle the shroud around to break the tim seal to the gpu.
    http://www.anandtech.com/print/3809
    "Sometimes you will never know the true value of a moment until it becomes a memory"
    Asrock x99oc 5960x..........Asrock z77 x6/3770
    GSkills 32gb........................16gigZ Corsair
    Sapphire fury nitro crossfire ...........Gigabyte 290 crossfired
    X-Fi titanium Fatal pro.................H2O cooling
    480 crucial/480 samsung..... .......240gig ssd
    Siverstone 1500wt'r.....................Corsair1000HX
    MyHeat
  3. #3
    Join Date
    Oct 2011
    its actually just 4 screws i have 2 of them one came apart very easily. this one though no matter what i do it wont budge.. not sure what I should do here....
  4. #4
    Join Date
    Oct 2011
    Got it! Thanks for your help!
  5. #5
    Senior Member
    OnDborder's Avatar
    10 Year Badge
    Join Date
    May 2001
    HOT 'n Arizona
    Is this the one?
    http://hothardware.com/image_popup.a...cleid=1534&t=a
    Could be just stubborn paste.
    MyHeat
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
