- Dec 16, 2003
- ON, CA
I'm running an a v7 SMP client using Win7 x64->VMWare->Ubuntu 10.10 and receive the following errors in the logs from time to time. The second problem is one missed QRB , I think because the correct work server went down and work unit was received from another (best guess). Any insight greatly appreciated.
12:39:33:SocketDevice::read(): End of stream
12:39:33:Server connection id=2 on 0.0.0.0:36330 from 127.0.0.1
12:39:33:Started thread 12 on PID 1420
12:39:33:Server connection id=1 ended
12:40:59:SocketDevice::write(): Send error: 32: Broken pipe
12:40:59:Server connection id=3 on 0.0.0.0:36330 from 127.0.0.1
12:40:59:Started thread 13 on PID 1420
12:40:59:Server connection id=2 ended
12:47:45:SocketDevice::read(): End of stream
12:47:45:Server connection id=4 on 0.0.0.0:36330 from 127.0.0.1
12:47:45:Started thread 14 on PID 1420
12:47:45:Server connection id=3 ended
12:50:45:Unit 00:Completed 300000 out of 1500000 steps (20%)
13:03:58:Unit 00:Completed 315000 out of 1500000 steps (21%)
13:07:55:SocketDevice::read(): End of stream
13:07:56:Server connection id=5 on 0.0.0.0:36330 from 127.0.0.1
13:07:56:Started thread 15 on PID 1420
13:07:56:Server connection id=4 ended
13:09:23:SocketDevice::write(): Send error: 32: Broken pipe
13:09:23:Server connection id=6 on 0.0.0.0:36330 from 127.0.0.1
13:09:23:Started thread 16 on PID 1420
13:09:24:SocketDevice::write(): Send error: 32: Broken pipe
13:09:24:Server connection id=5 ended
15:04:12:Unit 01:Completed 500000 out of 500000 steps (100%)
15:04:13:Unit 01ynamicWrapper: Finished Work Unit: sleep=10000
15:04:13:Connecting to assign3.stanford.edu:8080
15:04:13:News: Welcome to Folding@Home
15:04:13:Assigned to work server 171.64.65.99
15:04:13:Requesting new work unit for slot 00: RUNNING smp:8 from 171.64.65.99
15:04:13:Connecting to 171.64.65.99:8080
15:04:14:Slot 00: Downloading 1.96MiB
15:04:20:Slot 00: 92.49%
15:04:20:Slot 00: Download complete
15:04:20:Received Unit: id:00 stateOWNLOAD error:OK project:7808 run:7 clone:245 gen:20 core:0xa4 unit:0x0000002e0a3b1e874e30ff15a3d727f2
15:04:23:Unit 01:
15:04:23:Unit 01:Finished Work Unit:
15:04:23:Unit 01:- Reading up to 24721224 from "01/wudata_01.trr": Read 24721224
15:04:23:Unit 01:trr file hash check passed.
15:04:23:Unit 01:edr file hash check passed.
15:04:23:Unit 01:logfile size: 31479
15:04:23:Unit 01:Leaving Run
15:04:24:Unit 01:- Writing 24760059 bytes of core data to disk...
15:04:28:Unit 01one: 24759547 -> 19666129 (compressed to 79.4 percent)
15:04:28:Unit 01: ... Done.
15:04:33:Unit 01:- Shutting down core
15:04:33:Unit 01:
15:04:33:Unit 01:Folding@home Core Shutdown: FINISHED_UNIT
15:04:33:FahCore, running Unit 01, returned: FINISHED_UNIT (100 = 0x64)
15:04:33:Sending unit results: id:01 state:SEND error:OK project:7905 run:69 clone:43 gen:1 core:0xa4 unit:0x0000000100ac9c234ecffbb9eef4af88
15:04:33:Unit 01: Uploading 18.76MiB to 128.113.12.163
15:04:33:Connecting to 128.113.12.163:8080
15:04:33:Starting Unit 00
15:04:33:Running core: /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -lifeline 1515 -version 701 -checkpoint 3 -np 8
15:04:33:Started core on PID 9309
15:04:33:Started thread 14 on PID 1515
15:04:33:FahCore 0xa4 started
15:04:34:Unit 00:
15:04:34:Unit 00:*------------------------------*
15:04:34:Unit 00:Folding@Home Gromacs GB Core
15:04:34:Unit 00:Version 2.27 (Dec. 15, 2010)
15:04:34:Unit 00:
15:04:34:Unit 00reparing to commence simulation
15:04:34:Unit 00:- Looking at optimizations...
15:04:34:Unit 00:- Created dyn
15:04:34:Unit 00:- Files status OK
15:04:34:Unit 00:- Expanded 2054309 -> 5365960 (decompressed 261.2 percent)
15:04:34:Unit 00:Called DecompressByteArray: compressed_data_size=2054309 data_size=5365960, decompressed_data_size=5365960 diff=0
15:04:34:Unit 00:- Digital signature verified
15:04:34:Unit 00:
15:04:34:Unit 00roject: 7808 (Run 7, Clone 245, Gen 20)
15:04:34:Unit 00:
15:04:34:Unit 00:Assembly optimizations on if available.
15:04:34:Unit 00:Entering M.D.
15:04:39:Unit 01: 2.56%
15:04:41:Unit 00:Completed 0 out of 1500000 steps (0%)
15:04:45:Unit 01: 4.48%
15:04:51:Unit 01: 6.39%
15:04:57:Unit 01: 8.33%
15:05:03:Unit 01: 10.25%
15:05:09:Unit 01: 12.23%
15:05:15:Unit 01: 14.14%
15:05:48:Unit 01: 15.22%
15:06:18:Unit 01: 15.25%
15:06:48:Unit 01: 15.27%
15:07:18:Unit 01: 15.29%
15:07:48:Unit 01: 15.31%
15:08:18:Unit 01: 15.31%
15:08:18:SocketDevice::write(): Send of size 4096 failed. Sent 3560 bytes
15:08:48:Unit 01: 15.31%
15:08:48:SocketDevice::write(): Send of size 4096 failed. Sent 0 bytes
15:09:18:SocketDevice::write(): Send of size 4096 failed. Sent 0 bytes
15:09:18:SocketDevice::write(): Socket not open
[93m15:09:18:WARNING: Exception: Failed to send results to work server: Upload failed[0m
15:09:18:Trying to send results to collection server
15:09:18:Unit 01: Uploading 18.76MiB to 129.74.85.16
15:09:18:Connecting to 129.74.85.16:8080
15:09:24:Unit 01: 2.56%
15:09:30:Unit 01: 4.50%
15:09:36:Unit 01: 6.37%
15:09:42:Unit 01: 8.41%
15:09:48:Unit 01: 10.37%
15:09:54:Unit 01: 12.27%
15:10:00:Unit 01: 14.22%
15:10:06:Unit 01: 16.16%
15:10:12:Unit 01: 18.12%
15:10:18:Unit 01: 20.06%
15:10:24:Unit 01: 21.99%
15:10:30:Unit 01: 23.95%
15:10:36:Unit 01: 25.87%
15:10:42:Unit 01: 27.80%
15:10:48:Unit 01: 29.74%
15:10:54:Unit 01: 31.68%
15:11:00:Unit 01: 33.62%
15:11:06:Unit 01: 35.57%
15:11:12:Unit 01: 37.49%
15:11:18:Unit 01: 39.45%
15:11:24:Unit 01: 41.38%
15:11:30:Unit 01: 43.32%
15:11:36:Unit 01: 45.26%
15:11:42:Unit 01: 47.19%
15:11:48:Unit 01: 49.11%
15:11:54:Unit 01: 51.07%
15:12:00:Unit 01: 53.01%
15:12:06:Unit 01: 54.94%
15:12:12:Unit 01: 56.88%
15:12:18:Unit 01: 58.84%
15:12:24:Unit 01: 60.75%
15:12:30:Unit 01: 62.69%
15:12:36:Unit 01: 64.65%
15:12:42:Unit 01: 66.58%
15:12:48:Unit 01: 68.52%
15:12:49:Unit 00:Completed 15000 out of 1500000 steps (1%)
15:12:54:Unit 01: 70.46%
15:13:00:Unit 01: 72.40%
15:13:06:Unit 01: 74.33%
15:13:12:Unit 01: 76.29%
15:13:18:Unit 01: 78.06%
15:13:24:Unit 01: 80.14%
15:13:30:Unit 01: 82.10%
15:13:36:Unit 01: 83.95%
15:13:42:Unit 01: 85.97%
15:13:48:Unit 01: 87.91%
15:13:54:Unit 01: 89.66%
15:14:00:Unit 01: 91.76%
15:14:06:Unit 01: 93.72%
15:14:12:Unit 01: 95.60%
15:14:18:Unit 01: 97.60%
15:14:24:Unit 01: 99.55%
15:14:30:Unit 01: Upload complete
15:14:30:Server responded WORK_ACK (400)
15:14:30:Final credit estimate, 487.00 points
15:14:30:Cleaning up Unit 01
