- Dec 26, 2004
Awesome build so far! I'm jealous of that undercoating, I might have to copy you.
A quick tip, If you have the time, I'd cut a notch into the side of the middle plate that will be behind the motherboard. That way, you can run PSU cables through this notch behind the motherboard tray without having much sticking out (allowing you to close your back side-panel without much issue). This is something I overlooked when I finished my build. Perhaps over the summer when I have some spare time, I'll pull the rig apart and bust out the dremel
I'm curious to how you plan on mounting your radiators? I had to mock up the way I mounted mine in my case (see my build log in sig) and it works well, but I feel like I could have done a better job. I've seen lots of TJ-07 builds with single/double radiators in the bottom, but no one ever puts detail into how the radiators are secured to the bottom of the case.
