- Jul 29, 2011
- Buenos Aires, Argentina
Guys, I have a few doubts...My cpu has arrived and I still lack the rest of the rig basically
I have an I7 2600k, and no cooler whatsoever, that's all.
-Memory-wise I'm not sure of what would be best for ppd: I can get a cheap 2x4gb Mushkin Silverline 1333mhz cl9 kit, or a bit more expensive -but cheap too- Patriot Viper 1866 2x4gb kit cl9 also. Suggestions?
-Motherboard...hmmm I was thinking on getting an Asrock Z68 Extreme 3 gen3 for future compatibility with pci-e 3.0 and Ivy cpus, plus it offers good bang/buck ratio, I think. What do you think?
-PSU...this should be one of my priorities as it'll be on most of the time. I'm thinking of getting a good, reliable 550-650w unit. Would you say the Antec VPBasiq series is good? Or this Gygabyte 500w psu?
Again suggestions are welcome.
-Cooling: I was thinking on buying a Venomous X I found for dirt cheap -I'll run stock clocks on passive cooling for a couple of days once I get the mobo/ram/psu (then buy some good dual fans and overclock)
-GPU: I'm not sure if folding with the gpu would be worth it with a 2600k chip...what do you think? Also, most likely I'll get a 7950/70 card when the time comes and I upgrade my crt 15" monitor to a 22" LCD @ 1080p
So, to sum it up, I'll be running stock clocks for a while, and onboard igpu too, at 1024x768 or similar for a month or two, whilst doing my SMP folding.
What do you think?
Thanks!
What do you think?
Thanks!
