Results 1 to 2 of 2
  1. #1
    Registered Godo's Avatar
    Join Date
    Feb 2012
    UK
    would there be a big difference in performance between a 4.4 and 4.6 i5 2500k oc
    cause of my mobo, I don't have manual oc for vore voltage, so i have to settle for 4.4ghz to keep idle voltage to my satisfactory requirements. 4.6 auto v too much.
    would there be that much diff in realitime appz and games anyway?
    (i know it's a stupid Q but still)
    cpu: i5 2500k @ 4.4ghz
    memory: 2x4gb corsair xms3 @ 1600mhz
    mobo: GA-Z68AP-D3
    gpu: hd3000 intel
    Hdd: OCZ Agility 3 120GB 2.5" SATA-3 ssd, 500gb wd, 300g wd
    psu: Cooler Master 700M
    Case: Arc Midi Tower (fractal design)
  2. #2
    Insatiably Malcontent
    Senior Member
    johan851's Avatar
    10 Year Badge
    Join Date
    Jul 2002
    Seattle, WA
    Well, 4.6GHz is 0.2GHz faster than 4.4GHz. That's about 4.5%. Clock speed doesn't usually scale 1:1 with performance, so the actual difference in speed will be less than that. Less than 4.5% isn't a whole lot, so I wouldn't worry too much about it.
    ASUS P8Z77-V | 2500K | 2x4GB Samsung DDR3 | GTX 750 Ti 2GB
    512GB Crucial MX100 | Seasonic S12 600w
    y2 DAC --> Custom M^3 --> Custom LM3875 ChipAmp --> Modula MTs
    Dual Dell U2415
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
