im goin to tell u the specs of my pc then get into my issues...
AMD Phenom 9950 X4 Black Edition
OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066
ASUS EAH4850 MATRIX/HTDI/512M/A Radeon HD 4850 512MB 256-bit
ASUS M3A79-T Deluxe AM2+/AM2 AMD 790FX ATX AMD Motherboard
the pc is 3 yrs old and have been using it to play the same game for 3 yrs now and issues just started in december.. i would get a blue screen after playing wow and listening to music at same time with the pc output to my 52inch tv... i had no issues playing for 8 hrs a day everyday and not turning off pc next to ever till end of december... i noticed around new years my video cards fan died so i called asus.. they had me send it in and they replaced it.. while they had it a month i went out and bought a new video card till the asus one got fixed.. 1st card did same thing.. i figured it was just a junk card.. took it back and got another card.. same thing...so i waited till i got the new card from asus and put it in and issues still there blue screen and it would restart.. so i figure outputing music and video to my tv was the reason so i quit playing music while i played.. its still happening.. more and more frequent... today the pc lasted 1 hr playing b4 it restarted itself.. so i look online and find prime95 stress test.. i run it on blend.. after about 3 min pc resets...then i let it sit awhile and i run it on small fft and again after about 3 min the pc reset.. i did notice the processors temp went to almost 160 degrees right b4 it locked up...while typing this its sitting at 134 degrees... would you people think i have a processor issue causing all these blue screens... i feel the pc aint worth fixing.. and i doubt it will run diablo3 with the issues its been having but i would like to wait a lil while b4 i build another pc... ty in advance
