- Apr 2, 2012
Hi, there's probably been millions of threads like this - sorry.
I know you guys are experts - I've decided that I want to build my first gaming rig, but I have a budget and a limited experience in constructing PC's. I'm hoping some of you can help?
BUDGET -
around $1,000
GOAL -
to build a gaming rig that will require as little post-build maintenance as possible. Simplistic design (meaning no flashy LEDs to manage) & ability to max out BF3 at a high res.
WHAT I NEED -
could some of you suggest builds that fit my budget that maximizes performance? (I would prefer no water-cooling, sleek black tower)
* - Parts I need
* - Parts I have
BUILD (Add suggestions/changes you would make or deals on items if you can, it would be much appreciated!)
And thank you in advance
BUDGET -
around $1,000
GOAL -
WHAT I NEED -
* - Parts I need
* - Parts I have
- CASE - Cooler Master HAF XM *
- http://www.newegg.com/Product/Product.aspx?Item=N82E16811119257
- PSU - CORSAIR Enthusiast Series TX750 V2 750W *
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021 - CPU - Intel i5-3570K - *
http://www.microcenter.com/single_product_results.phtml?product_id=0388577 - CPU Cooler - Cooler Master Hyper 212+ *
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065 - RAM - Corsair Vengeance 8GB DDR3 (2x4GB) *
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345 - MoBo - ASRock Z77 Extreme4 Gen3 *
http://www.microcenter.com/single_product_results.phtml?product_id=0387554 - HDD - Seagate Barracuda 1TB *
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840 - BD/DVD Burner - Sony Optiarc AD7280S-OB DVD BURNER *
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1387814&CatId=1624 - GPU - Gigabyte GTX 670 Windforce - *
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125423 - OS - Windows 7 Professional *
