I've found out, that multiplier for my cpu won't go above x4.
I've got windows7 (32bit) and CPU is Intel Core2Duo P8600, it should have multiplier of x9.
I think it's not caused by the power savings because I've set the OS options for 100% performance. I was using CPU-Z for some tests:
Multiplier was set to x4 while idle and the power saving options in win7 were set to 100%.
While the CPU was stressed at 100%, multiplier was still at x4.
I could drop the multiplier to x2.5/x3 by changing the performance on lower settings in the power saving options.
Also I've had my CPU stressed for some time and the CPU temp went up to 54C so I don't think these are overheating problems.
Is there any way to change the maximum multiplier back to x9? I don't even know what changed it to the max of x4.
I don't have the SpeedStep options in BIOS.
EDIT:
So I was doing some more testing and after reboot, the multiplier can go up to x9, but after some time of stressing it's locked on up to x4.
What is more if i wait some time in idle, it can go back to x9 for a while, but as before it'll lock itself at x4 after short period of time.
As said before, I'm sure it's not because of overheating, I'm constantly checking the temperature of CPU and it never raised higher than 55C (on both multi x9 and x4)
EDIT:
