- Feb 20, 2012
- Wisconsin, USA
Alright, so I was just going to run the GPU client for tonight, to see how bad my Radeon HD 6850 was, but I ran into this.
What's going on? I think it was just a ton of failed WU's that were happening to my card, (I turned off my passkey when doing this, just in case)
But if I did that while I was using my passkey, wouldn't that drop me out of being eligible for bonus points?
Fail at me not knowing this.
Code:
04:31:08:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:31:08:Adding folding slot 01: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]"
04:31:09:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
04:31:09:Saving configuration to config.xml
04:31:09:<config>
04:31:09: <!-- Network -->
04:31:09: <proxy v=':8080'/>
04:31:09:
04:31:09: <!-- User Information -->
04:31:09: <team v='32'/>
04:31:09: <user v='Sky'/>
04:31:09:
04:31:09: <!-- Folding Slots -->
04:31:09: <slot id='0' type='SMP'/>
04:31:09: <slot id='1' type='GPU'/>
04:31:09:</config>
04:31:09:WU01:FS01:News: Welcome to Folding@Home
04:31:09:WU01:FS01:Assigned to work server 171.67.108.44
04:31:09:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
04:31:09:WU01:FS01:Connecting to 171.67.108.44:8080
04:31:09:WU01:FS01:Downloading 44.28KiB
04:31:10:WU01:FS01:Download complete
04:31:10:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:OK project:11293 run:22 clone:432 gen:5 core:0x16 unit:0x000001606652edbc4d94b970f72d106a
04:31:10:WU01:FS01:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah
04:31:10:WU01:FS01:Connecting to www.stanford.edu:80
04:31:10:WU01:FS01:FahCore 16: Downloading 1.04MiB
04:31:16:WU01:FS01:FahCore 16: 100.00%
04:31:16:WU01:FS01:FahCore 16: Download complete
04:31:16:WU01:FS01:Valid core signature
04:31:16:WU01:FS01:Unpacked 2.33MiB to cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe
04:31:16:WU01:FS01:Starting
04:31:16:WU01:FS01:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:/Users/Sky/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 701 -lifeline 292 -checkpoint 15 -gpu 0
04:31:16:WU01:FS01:Started FahCore on PID 3764
04:31:16:WU01:FS01:Core PID:1100
04:31:16:WU01:FS01:FahCore 0x16 started
04:31:16:WU01:FS01:Downloading project 11293 description
04:31:16:WU01:FS01:Connecting to fah-web.stanford.edu:80
04:31:16:WU01:FS01:0x16:
04:31:16:WU01:FS01:0x16:*------------------------------*
04:31:16:WU01:FS01:0x16:Folding@Home GPU Core
04:31:16:WU01:FS01:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
04:31:16:WU01:FS01:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
04:31:16:WU01:FS01:0x16:Build host: user-f6d030f24f
04:31:16:WU01:FS01:0x16:Board Type: AMD/OpenCL
04:31:16:WU01:FS01:0x16:Core : x=16
04:31:16:WU01:FS01:0x16: Window's signal control handler registered.
04:31:16:WU01:FS01:0x16:Preparing to commence simulation
04:31:16:WU01:FS01:0x16:- Looking at optimizations...
04:31:16:WU01:FS01:0x16:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
04:31:16:WU01:FS01:0x16:- Created dyn
04:31:16:WU01:FS01:0x16:- Files status OK
04:31:16:WU01:FS01:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
04:31:16:WU01:FS01:0x16:- Expanded 44830 -> 171163 (decompressed 381.8 percent)
04:31:16:WU01:FS01:0x16:Called DecompressByteArray: compressed_data_size=44830 data_size=171163, decompressed_data_size=171163 diff=0
04:31:16:WU01:FS01:0x16:- Digital signature verified
04:31:16:WU01:FS01:0x16:Project: 11293 (Run 22, Clone 432, Gen 5)
04:31:16:WU01:FS01:0x16:Assembly optimizations on if available.
04:31:16:WU01:FS01:0x16:Entering M.D.
04:31:16:WU01:FS01:Project 11293 description downloaded successfully
04:31:18:WU01:FS01:0x16:Tpr hash 01/wudata_01.tpr: 4134251778 3036659194 3251259505 2081988639 2000521015
04:31:18:WU01:FS01:0x16:Working on ALZHEIMER DISEASE AMYLOID
04:31:18:WU01:FS01:0x16:Client config unavailable.
04:31:18:WU01:FS01:0x16:Starting GUI Server
04:31:25:WU01:FS01:0x16:Finished fah_main
04:31:25:WU01:FS01:0x16:Successful run
04:31:25:WU01:FS01:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
04:31:35:WU01:FS01:0x16:Reserved 0 bytes for xtc file; Cosm status=0
04:31:35:WU01:FS01:0x16:Reserved 0 0 786430464 bytes for arc file=<01/wudata_01.trr> Cosm status=0
04:31:35:WU01:FS01:0x16:Allocated 0 bytes for edr file
04:31:35:WU01:FS01:0x16:Error: could not open bedfile, but going on anyway
04:31:35:WU01:FS01:0x16:- Checksum of file (01/wudata_01.edr) read from disk doesn't match
04:31:35:WU01:FS01:0x16:edrfile file hash check failed.
04:31:35:WU01:FS01:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
04:31:35:WU01:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
04:31:35:WARNING:WU01:FS01:Fatal error, dumping
04:31:35:WU01:FS01:Sending unit results: id:01 state:SEND error:DUMPED project:11293 run:22 clone:432 gen:5 core:0x16 unit:0x000001606652edbc4d94b970f72d106a
04:31:35:WU01:FS01:Connecting to 171.67.108.44:8080
04:31:36:WU02:FS01:Connecting to assign-GPU.stanford.edu:80
04:31:36:WU01:FS01:Server responded WORK_ACK (400)
04:31:36:WU01:FS01:Cleaning up
04:31:36:WU02:FS01:News: Welcome to Folding@Home
04:31:36:WU02:FS01:Assigned to work server 171.67.108.44
04:31:36:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
04:31:36:WU02:FS01:Connecting to 171.67.108.44:8080
04:31:36:WU02:FS01:Downloading 44.28KiB
04:31:37:WU02:FS01:Download complete
04:31:37:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:OK project:11293 run:23 clone:321 gen:6 core:0x16 unit:0x000001a16652edbc4d94b99bc1ac9178
04:31:37:WU02:FS01:Starting
04:31:37:WU02:FS01:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:/Users/Sky/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 701 -lifeline 292 -checkpoint 15 -gpu 0
04:31:37:WU02:FS01:Started FahCore on PID 820
04:31:37:WU02:FS01:Core PID:1588
04:31:37:WU02:FS01:FahCore 0x16 started
04:31:37:WU02:FS01:0x16:
04:31:37:WU02:FS01:0x16:*------------------------------*
04:31:37:WU02:FS01:0x16:Folding@Home GPU Core
04:31:37:WU02:FS01:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
04:31:37:WU02:FS01:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
04:31:37:WU02:FS01:0x16:Build host: user-f6d030f24f
04:31:37:WU02:FS01:0x16:Board Type: AMD/OpenCL
04:31:37:WU02:FS01:0x16:Core : x=16
04:31:37:WU02:FS01:0x16: Window's signal control handler registered.
04:31:37:WU02:FS01:0x16:Preparing to commence simulation
04:31:37:WU02:FS01:0x16:- Looking at optimizations...
04:31:37:WU02:FS01:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
04:31:37:WU02:FS01:0x16:- Created dyn
04:31:37:WU02:FS01:0x16:- Files status OK
04:31:37:WU02:FS01:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
04:31:37:WU02:FS01:0x16:- Expanded 44827 -> 171163 (decompressed 381.8 percent)
04:31:37:WU02:FS01:0x16:Called DecompressByteArray: compressed_data_size=44827 data_size=171163, decompressed_data_size=171163 diff=0
04:31:37:WU02:FS01:0x16:- Digital signature verified
04:31:37:WU02:FS01:0x16:Project: 11293 (Run 23, Clone 321, Gen 6)
04:31:37:WU02:FS01:0x16:Assembly optimizations on if available.
04:31:37:WU02:FS01:0x16:Entering M.D.
04:31:39:WU02:FS01:0x16:Tpr hash 02/wudata_01.tpr: 3441323048 1911303106 2824313749 886607746 1723745190
04:31:39:WU02:FS01:0x16:Working on ALZHEIMER DISEASE AMYLOID
04:31:39:WU02:FS01:0x16:Client config unavailable.
04:31:39:WU02:FS01:0x16:Starting GUI Server
04:31:39:WU02:FS01:0x16:Finished fah_main
04:31:39:WU02:FS01:0x16:Successful run
04:31:39:WU02:FS01:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
04:31:49:WU02:FS01:0x16:Reserved 0 bytes for xtc file; Cosm status=0
04:31:49:WU02:FS01:0x16:Reserved 0 0 786430464 bytes for arc file=<02/wudata_01.trr> Cosm status=0
04:31:49:WU02:FS01:0x16:Allocated 0 bytes for edr file
04:31:49:WU02:FS01:0x16:Error: could not open bedfile, but going on anyway
04:31:49:WU02:FS01:0x16:- Checksum of file (02/wudata_01.edr) read from disk doesn't match
04:31:49:WU02:FS01:0x16:edrfile file hash check failed.
04:31:49:WU02:FS01:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
04:31:50:WU02:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
04:31:50:WARNING:WU02:FS01:Fatal error, dumping
04:31:50:WU02:FS01:Sending unit results: id:02 state:SEND error:DUMPED project:11293 run:23 clone:321 gen:6 core:0x16 unit:0x000001a16652edbc4d94b99bc1ac9178
04:31:50:WU02:FS01:Connecting to 171.67.108.44:8080
04:31:50:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
04:31:50:WU02:FS01:Server responded WORK_ACK (400)
04:31:50:WU02:FS01:Cleaning up
04:31:50:WU01:FS01:News: Welcome to Folding@Home
04:31:50:WU01:FS01:Assigned to work server 171.67.108.44
04:31:50:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
04:31:50:WU01:FS01:Connecting to 171.67.108.44:8080
04:31:51:WU01:FS01:Downloading 44.31KiB
04:31:51:WU01:FS01:Download complete
04:31:51:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:OK project:11293 run:7 clone:298 gen:6 core:0x16 unit:0x000001c06652edbc4d92573ef71c3037
04:31:51:WU01:FS01:Starting
04:31:51:WU01:FS01:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:/Users/Sky/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 701 -lifeline 292 -checkpoint 15 -gpu 0
04:31:51:WU01:FS01:Started FahCore on PID 1976
04:31:51:WU01:FS01:Core PID:4756
04:31:51:WU01:FS01:FahCore 0x16 started
04:31:52:WU01:FS01:0x16:
04:31:52:WU01:FS01:0x16:*------------------------------*
04:31:52:WU01:FS01:0x16:Folding@Home GPU Core
04:31:52:WU01:FS01:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
04:31:52:WU01:FS01:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
04:31:52:WU01:FS01:0x16:Build host: user-f6d030f24f
04:31:52:WU01:FS01:0x16:Board Type: AMD/OpenCL
04:31:52:WU01:FS01:0x16:Core : x=16
04:31:52:WU01:FS01:0x16: Window's signal control handler registered.
04:31:52:WU01:FS01:0x16:Preparing to commence simulation
04:31:52:WU01:FS01:0x16:- Looking at optimizations...
04:31:52:WU01:FS01:0x16:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
04:31:52:WU01:FS01:0x16:- Created dyn
04:31:52:WU01:FS01:0x16:- Files status OK
04:31:52:WU01:FS01:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
04:31:52:WU01:FS01:0x16:- Expanded 44860 -> 171163 (decompressed 381.5 percent)
04:31:52:WU01:FS01:0x16:Called DecompressByteArray: compressed_data_size=44860 data_size=171163, decompressed_data_size=171163 diff=0
04:31:52:WU01:FS01:0x16:- Digital signature verified
04:31:52:WU01:FS01:0x16:Project: 11293 (Run 7, Clone 298, Gen 6)
04:31:52:WU01:FS01:0x16:Assembly optimizations on if available.
04:31:52:WU01:FS01:0x16:Entering M.D.
04:31:53:WU01:FS01:0x16:Tpr hash 01/wudata_01.tpr: 3808521670 3815539867 3924032311 334544376 3828546911
04:31:53:WU01:FS01:0x16:Working on ALZHEIMER DISEASE AMYLOID
04:31:53:WU01:FS01:0x16:Client config unavailable.
04:31:54:WU01:FS01:0x16:Starting GUI Server
04:31:54:WU01:FS01:0x16:Finished fah_main
04:31:54:WU01:FS01:0x16:Successful run
04:31:54:WU01:FS01:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
04:32:04:WU01:FS01:0x16:Reserved 0 bytes for xtc file; Cosm status=0
04:32:04:WU01:FS01:0x16:Reserved 0 0 786430464 bytes for arc file=<01/wudata_01.trr> Cosm status=0
04:32:04:WU01:FS01:0x16:Allocated 0 bytes for edr file
04:32:04:WU01:FS01:0x16:Error: could not open bedfile, but going on anyway
04:32:04:WU01:FS01:0x16:- Checksum of file (01/wudata_01.edr) read from disk doesn't match
04:32:04:WU01:FS01:0x16:edrfile file hash check failed.
04:32:04:WU01:FS01:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
04:32:04:WU01:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
04:32:04:WARNING:WU01:FS01:Fatal error, dumping
04:32:04:WU01:FS01:Sending unit results: id:01 state:SEND error:DUMPED project:11293 run:7 clone:298 gen:6 core:0x16 unit:0x000001c06652edbc4d92573ef71c3037
04:32:04:WU01:FS01:Connecting to 171.67.108.44:8080
04:32:04:WU02:FS01:Connecting to assign-GPU.stanford.edu:80
04:32:04:WU01:FS01:Server responded WORK_ACK (400)
04:32:04:WU01:FS01:Cleaning up
04:32:05:WU02:FS01:News: Welcome to Folding@Home
04:32:05:WU02:FS01:Assigned to work server 171.67.108.44
04:32:05:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:"Barts PRO [ATI Radeon HD 6800 Series]" from 171.67.108.44
04:32:05:WU02:FS01:Connecting to 171.67.108.44:8080
04:32:05:WU02:FS01:Downloading 44.29KiB
04:32:06:WU02:FS01:Download complete
04:32:06:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:OK project:11293 run:19 clone:453 gen:6 core:0x16 unit:0x000000876652edbc4d94b8d1a60d14bd
04:32:06:WU02:FS01:Starting
04:32:06:WU02:FS01:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:/Users/Sky/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 701 -lifeline 292 -checkpoint 15 -gpu 0
04:32:06:WU02:FS01:Started FahCore on PID 4244
04:32:06:WU02:FS01:Core PID:700
04:32:06:WU02:FS01:FahCore 0x16 started
04:32:06:WU02:FS01:0x16:
04:32:06:WU02:FS01:0x16:*------------------------------*
04:32:06:WU02:FS01:0x16:Folding@Home GPU Core
04:32:06:WU02:FS01:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
04:32:06:WU02:FS01:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
04:32:06:WU02:FS01:0x16:Build host: user-f6d030f24f
04:32:06:WU02:FS01:0x16:Board Type: AMD/OpenCL
04:32:06:WU02:FS01:0x16:Core : x=16
04:32:06:WU02:FS01:0x16: Window's signal control handler registered.
04:32:06:WU02:FS01:0x16:Preparing to commence simulation
04:32:06:WU02:FS01:0x16:- Looking at optimizations...
04:32:06:WU02:FS01:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
04:32:06:WU02:FS01:0x16:- Created dyn
04:32:06:WU02:FS01:0x16:- Files status OK
04:32:06:WU02:FS01:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
04:32:06:WU02:FS01:0x16:- Expanded 44845 -> 171163 (decompressed 381.6 percent)
04:32:06:WU02:FS01:0x16:Called DecompressByteArray: compressed_data_size=44845 data_size=171163, decompressed_data_size=171163 diff=0
04:32:06:WU02:FS01:0x16:- Digital signature verified
04:32:06:WU02:FS01:0x16:Project: 11293 (Run 19, Clone 453, Gen 6)
04:32:06:WU02:FS01:0x16:Assembly optimizations on if available.
04:32:06:WU02:FS01:0x16:Entering M.D.
04:32:08:WU02:FS01:0x16:Tpr hash 02/wudata_01.tpr: 2745411858 3506880766 1660212290 1786566620 2923560407
04:32:08:WU02:FS01:0x16:Working on ALZHEIMER DISEASE AMYLOID
04:32:08:WU02:FS01:0x16:Client config unavailable.
04:32:08:WU02:FS01:0x16:Starting GUI Server
04:32:08:WU02:FS01:0x16:Finished fah_main
04:32:08:WU02:FS01:0x16:Successful run
04:32:08:WU02:FS01:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
