I've been having A LOT of software crashing without warning. I finally ran memtest86+ I don't know how long I should have let the software run though. It ran for over 1.5 hrs, tests 1 through 8 or 9. Memtest was at default settings.
All the errors occurred during Test 5. The errors were highlight in red on my screen.
After the zero pass, it found 233 errors
After the 1 pass, it found 938 errors
After pass 2, it was up to 1,450 errors (I'm assuming in total)
Few questions:
1. How long should I have run the test?
2. I assume my 2 sticks of RAM are now bad?
If so, I need to more sticks of RAM to keep this computer running.
Memtest86 screen's read w/the following for RAM settings:
167MHz (DDR 334) CAS 2-3-3-7, Dual Channel 128 bits
Can I still get memory for this mobo? If so, I'd take any recommendations. I don't need anything super speedy, as I'm building a new rig. However, I do want something that will keep this computer running.
Thanks in advance.
If anyone needs to see my previous BSOD post here it is
BSOD/Software Crashing
Few questions:
Thanks in advance.
