- Aug 11, 2008
It sucks that you can't run what clocks you want for clock-for-clock tests because the boost clock varies throughout, and how high the boost goes and when it changes isn't the same during multiple runs of the same test either. I can do "same OC" tests if you want, max OC tests wouldn't be a good choice for comparison if one can run higher clocks than the other in some tests.
