- Thread Starter
- #41
Alright time to swap those cpus - out with the 920:
And in with the 990x:
Close it up:
Mount the CPU block and add the g3/8 adapters - luckily the 5Noz has a very wide port spacing:
Which means you can mount the high flow VL4N quick disconnects - unfortunately they are g 3/8 and don't come with right angle options, so I have to have adapters both ends and then a g1/4 female to female before I can add in the 90 degree rotary fitting:
Here we are with the old GPUs mounted too:
And here's how it will look as this will be the reverse ATX side:
Now it's time to repurpose that clown board:
And done til the case comes:
Close it up:
