- Apr 27, 2011
Hi there dear overclockers couple days ago iv been changeing round my CPU to check if another one is working and i had a bit of a incident with the thermal paste bit of it got on to the pins tryd to be gentle and took most of it off. put it back it it seems that the system is working ok run some tests temperature was a bit higher but inWprime on stock clock 32m was still rond 13.sec but when i switch on WoW for example it runs smooth few secs then it slows down and work is very uneven. Even when i drop the graphics right down.
Skyrim on the other hand works gud but another game has the same problem as WoW. i had a similar experience when i put the voltage bit to low on the CPU please HELP OVERCLOCKERS
