- Jul 7, 2012
Hi ive got my paws on some delta pfc1212de's their the 3.24a not 4.0amp ones.from hp servers.
found some TFC's as well which are 2.4a not higher ones ive seen.
What i needed some help on/with is a controller etc im looking to run3 or 4 fans from one knob depending if i go 360/420 or a 480?
My was of looking at it is that power will be through molex from psu and blue wire? pwm wire will go through controller so won't have to be something lots of power?
I did read on here from someone that pfc worked backwards ie when there cpu ramped up it went slower when they had to mobo's fan header? so hoping someone can talk sense etc
Do these need power to bring down or power to speed up? and ifso what volt's etc(mind you it is on full with i guess open circuit) only black and red connected atmo.
As even a so called well known pc shop in london gave me bumpf info!
Or as they say ive had all the tyre kickers round but no one knows how to drive the car!?.
Im looking for probably 3-4 channel one as looking to run two fans in the case base blowing upwards under GPU/mobo plus have two 80's in front and two in rear which are what case has from originally (Lian-Li PC70)
But thinking of getting better 80's in front for better airflow. (has ADDA's)
I have noticed that there seems to be some different specs even though same model so guess it's on revisions etc?
Or would it be that they wind down for Dell/HP etc?
Any i will bid you many thanks in advance.
