- Jun 16, 2012
- new jersey
im looking to install a drain somewhere on my system to use for maintenance and incase i have to drain it for some reason. i dont want to have it going anywhere so i have decided to put a drain port on the loop somewhere. but through my research i havent found much on the subject. i was thinking of putting either a splitter or a block that has 3 ports on it. something like this http://www.frozencpu.com/products/15165/ex-tub-1158/Alphacool_180_T_Block_-_Deep_Black.html then i was going to run a 2 or 3 inch peice of tube out and then put a pressure valve on it as the drain
i was going to put it right after my pump on the loop so that the pump could still run so i could drain the res enough.
tell me what you guys think and if you have any ideas let me know
