Staticshock
- Jul 23, 2012
Hi all,
I am looking to upgrade my case fans with quiter ones, but I don't want to affect my airflow. My specs are listed below.
Crosshair IV Mobo
Radeon 6970 HD GPU
Corsair 800D Case
Corsair H80 CPU Cooler
I currently have these 2 fans installed:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835130019
http://www.newegg.com/Product/Product.aspx?Item=N82E16835130022
What fans do you recommend? Again, I want quieter fans but with same or better airflow.
I also want to change the fans on my H80 CPU cooler, but I don't know what I should use... something about restricted vs unrestricted?
Since, I am asking about my airflow: due to my motherboard, my mounted GPU essentially juts out right in the middle of my case, with its fan pointing down. This has got to me messing with my airflow. How do you recommend I fix this?
Thanks for all your input in advance.
Crosshair IV Mobo
Radeon 6970 HD GPU
Corsair 800D Case
