Ok, so this cooler is giving me alot of trouble. During the installation i noticed that using the 3mm spacers would place the cooler too high; not connecting to the chip, so i left them out. The plate which connects cooler to the card is sitting on framing of the chip anyways and not directly on the card, is this ok?
The top vram bank will have to do without heatsinks, there is no way that it'll fit under the cooler. But XfX apparently is not cooling them either, cause the stock cooler is leaving them out in the open, so i guess it's not going to be worse than before. Please tell me my card won't get angry at me.
Next up is the power connection. The cooler has 4 cables, blue, red, yellow and black which would fit on top of a 4 pin plug; and an additional set of cables coming from the "maincable"; red, yellow and black which ends up in a 3 pin plug. But here's the deal, my card only has 2 pins, the stock cooler comes with a red/black cable.
Now what i did is removing the plastic around the pins on the card, and connecting the 3 pin plug, so that red and black (just like the stock cooler) will get power. Is this ok, or will this give me trouble?
I noticed the cooler has an adapter to plug it directly in your psu instead of the gpu, and it has 12v and 7v endings, how do i have to set this up if i need to do this?
I'm kinda on the edge about pluggin this card in right now, especially the power connection is giving me a headache, frying my card is the last thing i need right now. Overall i'm kinda angry at Arctic, recommending this cooler for a 6950 is pretty far strechted.
Thanks for your help guys.
