- Thread Starter
- #81
How much voltage is at the mod point itself under load?
slightly less, 1.14
The 1.17v is checked with a multimeter or with the ROG bits, right?
GPUz won't show a voltage change, that's why I ask.
When you turn the resistance down does the voltage at the mod point go down?
You're correct on mV to V.
That sounds about right for the mod point. The far side of the resistor (681) should be core voltage and that should be going up. The mod point voltage should stay more or less the same.
Temps going up indicate that *something* is certainly happening.
What does GPUz say the core voltage is under load?
I would guess that the .025mv difference is just a difference in calibration between the two, or even polling times. So not really a big deal. Low end multimeters are not known for their accuracy at low voltage ranges.
I'd probably be checking Temperatures at the core, temperatures at the vrms, and if that looked go i would give it more juice. 1.25volts isnt really that much that is actually the starting voltage required for alot the circuitry on the card.
You can always de-solder the mod wire and see what the voltage does.
So the mod is lowering the voltages?
VRM's seem to be getting a little hot.. getting to high 90's
is that F or C? if is 90c thats quite excessive, and they're gonna need some extra airflow, On alot of gigabytes cards I have found they tend to gimp on VRM cooling, and i have had it cause stability issues in the past. So i usually stick some extra heatsinks on their vrm's if they are accessible enough, or o go cut some some special.
