- May 24, 2001
- Maine, USA
- Thread Starter
- #21
I think everybody gave up
Gresyth said:just found this
try it also make SURE that File and Printer sharing is turned on on the second machine and that the drives are SHARED.
Gresyth said:From rereading the thread from the top saw something I missed before. Get rid of the domain, you dont need it. Domain is only set on VERY large networks like several hundred computers.
Eliminate the domain and set up a workgroup name. Use the same Workgroup name on both computers.
If all that is correct, unplug all your cables and then reconnect them to make sure they are all connected securely.
Try switching your cable positions, take cable 'A' and put it where cable B' was.
If that does'nt help try uninstalling everything and starting over from scratch.
Despotes said:
I'm not using a Domain. I was just asking about it earlier. I have the same Workgroup name on both computers. I already tried reversing the cables. I removed and reinstalled everything on my second computer a few days ago. I'll have to do the same on this one.
One thing I noticed. In Norton's Utilities/ System Information/Networking, I get "enumeration failed..." on my second computer. On this one, everything shows up fine.
So I believe the problem is with my second computer. Maybe I'll have to format and reinstall everything
