Hello people.
Any help would be appreciated, I'm not very technical so please be gentle with me.
I have moved my PC in front of a central heating radiator, about 26cm away from the rad.
I have put an extra fan at the top of the case, its a Noctua NF-S12B FLX and connected it to a molex.
Now I have one fan in the front of case, one at the back and one at the top, all 120mm
Now the a central heating will start staying on longer I want to fit another case fan on the front, I think that's the best place for it?
Also is it a PWM fan I need?
I've already got a fan splitter, 12 inch TX3 Fan Power Splitter Cable
Could I put the splitter on the chas fan on the mobo to feed the extra fan even though its already feeding the back fan?
The mobo is a ASRock A75M-HVS
Also does it control the fans?
Can you tell me what the PWR fan is for?
Thanks
Thanks
