- Jul 11, 2012
My original problem was when I installed my new graphics card(Radeon 7770), and plugged the monitor into the new plug, my monitor would not work (yellow light). I figured it was my PSU, so I bought a new one (500w). It's doing the same thing. After looking it up, the most common solution is disabling integrated graphics from the BIOS, but I cannot find where to do that in the BIOS. When I go into integrated peripherals the options are:
Onboard Sata Controller Enabled
Onboard Sata Mode AHCI
Onboard USB Controller Enabled
Legacy USB Support Enabled
USB Storage Emulation Auto
Onboard Audio Controller Enabled
Onboard LAN Controller Enabled
Onboard LAN Option ROM Disabled
Do I need to install the drivers from the CD and then switch to the new plug? Thanks!
