Having massive problems with this pc i bought.
IT CONTAINS:
•INTEL QUAD CORE Q6600 2.4GHZ PROCESSOR. 4 CORE PROCESSING.
•1GB XFX RADEON HD 6790 GDDR5 GAMING GRAPHICS CARD WITH MULTI MONITOR OUT PUT - 2 X DISPLAY PORT - 1 X HDMI - 2 X DVI
•4GB DDR2 800MHZ GEIL PERFORMANCE RAM
•ASUS P5Q EM 775 MOTHERBOARD WITH ONBOARD HIGH DEFINITION HDMI DVI OUTPUTS
•128GB OCZ SOLID 3 SSD DRIVE
•1TB SATA 7200RPM HARD DRIVE
•FRESH GENUINE WINDOWS 7 HOME PREMIUM 64 BIT SP1
•750W PSU
•22X SAMSUNG SATA DVDRW DRIVE
The bios shows the 2 hhd, and boots up withwindows 7 on the SSD. but when i go into system properties it only shows the ssd , doesnt show the other 1.
Buuuuuuuuuut...the main problem im having is with the gpu. It boots up asap but it black screens anything from 1 min to 4 mins.
Its apparnt that this is a common fault and all i need to do is disable the hardware accelerator but this option is greyed out,
ive updated the driver
ive switched the theme to windows basic..from the aero theme.
ive tried to edit settings within adobe but i cant find it in my c:/ drive but under the remove programs in control panel its there to br removed.
Pleeeeeeeeeeeeeease can someone help.... im a bit of a noob with pc's!
IT CONTAINS:
•750W PSU
