Aeronathan
- Oct 19, 2012
Hello, I am currently running 3 24" monitors and just got a 42" TV mounted to become my 4th monitor. The problem is, it can pick up my TV as a display, but when I try to extend the desktop onto it, I get "unable to save display settings".
I am running a HIS 7970 that supports up to 6 monitors, I have my setup as follows:
1 monitor running VGA into a DVI converter
1 monitor runnin DVI into a HDMI converter
1 monitor running DVI to Mini Display Port
I am trying to add the TV as a HDMI to Mini Display Port. CCC can pick it up and so can the windows one, but to use it in CCC it only gives me the option to disable one of the previous displays. I tried disabling Eyefinity also but still no luck. Unplugging one of them also enables the 4th monitor immediately. Can someobody explain what I might be doing wrong here? If any more information is needed I can supply.
