- Jul 30, 2009
Just curious if anyone is using a RAMDISK for folding, and if so, have you seen any improvement?
I remember people saying the Bigadv clients have a long clean up time when they are finished before sending the data off. I have never run bigadv so I'm not sure of all the details of this. But people were justifying keeping F@H on an SSD to help speed up this process. So while you may not see actual PPD increases, the time between starting a new wu could be reduced. Depending on how many you are able to pump out per day this could add up to more time your cores could be spent on folding rather than waiting for data.
My issue would be losing the data in the RAMdisk, I know I would forget to back it up before a reboot not to mention you lose all ability to recover your wu after a lock up.
Now, whenever you install Ubuntu, don't choose the default file system - ext4, but select ext3. Makes a LOT of difference!
Alternatively, find the mount options that change the behavior, and retain the benefits of ext4, or ask F@H to figure out what the heck their program is doing, since I have never seen such behavior in any other application (but I may just not have run enough applications to find any).
Note that this happens once per day, only. It's a small % of the overall time needed. I'd be worried about using an SSD, because FAH is writing to them, a lot - and SSD's do wear out rather quickly, compared to mechanical HD's.
And this is why I never use a SSD for Windows or running programs, now for backup, storing photos, music and stuff like that it's great. I have a MP3 player that had a 30GB HDD and I replaced it with a 32GB IDE SSD, it'll never wear out.
Why not optimize?
Because until somebody can point out other apps having the same issue with a measly 100MB write-to-disk taking 30 minutes, I'm going to be blaming F@H, and I shouldn't have to optimize for a broken program (not that I can even run bigadv anymore, since I have no 16-core machines)
But you can be sure the data writes that were optimized for ext3, will be redone IF other distro's settle on ext4 as their default file system.
Any idea how popular ext4 file system is?
It's been the default standard for a few years now with Fedora and Ubuntu. As I said earlier btrfs (Butter FS) is aiming to replace ext4 within a year or two as the default standard for most distros. Ext4 was mostly made to fix many shortcomings in ext3 while btrfs came up to speed and stabilized. As it stands right now brtfs is very usable and fast, I just wouldn't commit any mission critical data to it just yet, but for a 24/7 folding machine it should work just fine. SuSE Linux last I checked was already trying to push btrfs as the default.
btrfs (Butter FS)
Where'd that come from? If you want to pronounce it, use the "real" name B-Tree FS... Same number of syllables and more descriptive.
Btrfs (B-tree file system, variously pronounced "Butter F S", "Butterfuss", "Better F S",[1] or "B-tree F S"[2])
