Not sure if this belongs in Motherboard or Cooling so feel free to move to wherever.
On my 1st build and have come across a problem that I hope you guys can help with.
I have an ASUS P8Z77-V Deluxe mobo and a Zalman CNPS20LQ CPU Cooler and I'm installing into a Corsair SE 600T case and utilizing the rear fan that comes with case to set up a push/pull configuration on the cooler. I'm taking that that means pushing into the rad from internal fan and pulling out the back via rear case fan, please correct me if I've got that wrong.
My problems start with the Cooler installation -
To connect the cooler it says to 'plug fan cable into 4-pin cpu fan header on mobo' - no problems there and have done that.
My problem is that is then says 'connect pump cable into a 3-pin fan header on mobo' - there are no 3-pin fan headers only 4 so where do I plug this in?
I'm also not sure where to plug the lead from the rear fan into either, any ideas? It's a case fan so also 3-pin.
Hope that's enough info.
~Steve
~Steve
