Specs
Windows 8
A4-3400 (OC'd at 3.0ghz)
GSKILL DDR3 1600 Ram
XFX Core edition 6570 1GB
480W PSU
Okay so my XFX Core edition gives me the option to overclock up to
675 MHZ for the high performance GPU clock. For the memory clock it gives me the option of taking it to 1ghz.
Currently my settings are at 675(max) for the high performance GPU clock.
For the Memory clock its at 585MHZ.
The GPU runs at about 40 degrees C right now.
Anytime I take it past 585MHZ for overclocking these pink "artifacts" or structures appear on my screen and I switch it back.
So my question is is there anyway to stabilize the GPU? I took the memory clock up to 750MHZ this morning and it was stable for approximately 10 minutes then the display drivers failed. Is there anyway to stabilize the GPU or the drivers? I'm overclocking using AMD Catalyst.
Windows 8
480W PSU
